Re: 684 more hydraulic problems
Posted by pete 23 on September 04, 2011 at 10:34:11 from (74.32.234.149):
In Reply to: 684 more hydraulic problems posted by Marty from MN on September 04, 2011 at 08:35:17:
Like previous poster said, hand brake derbris may
be clogging the screen on the lube transfer pump.
When this happens the section of the rear housings
over fill one side and starve the other side. The
side that runs out of oil is the one where the hyd
pump pulls it's oil from. So,if it works after
standing for a short period of time and then quits
soon after I would suspect the screen is plugged.
If I remember correctly, you can access the screen
from that large round cover on side of tractor
that is for an aux pump to be mounted. To replace
the hand brake band is a major job. Of course,
proper oil level to start with and clean filter
is a must.
Today's Featured Article - Tractor of the Month - by Staff. decals, dependin upon the configuration of the parent company International Harvester in the year of production. For the purpose of this article, we will refer to the tractor as simply a "Farmall Cub". This little tractor was aimed at the needs of the small-acreage farmer - farms of 40 crop acres or less and truck gardens, or for larger farms that needed an extra tractor. Seven or eight implements were initially designed for it: Plow, Disc, Backblade, Sickle-Bar ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
