Posted by CNKS on September 03, 2011 at 07:44:00 from (216.144.104.128):
In Reply to: 300u clutch adjustment. posted by mike paulson on September 03, 2011 at 06:30:17:
If it has a TA and you are using Hytran, yes. If it is adjusted to spec, the linkage can be sloppy and part of the pedal "clearance" is due to the worn linkage, so you might have to change the pedal clearance slightly. Also, with the tractor running look at the release bearing through the hole underneath. Sometimes the bearing will be touching the fingers so that it spins all the time. This will cause bearing wear but should not harm the clutch plate because the fingers touch the bearing by centrifugal force rather than the clearance being too tight. You might have to adjust the clutch to compromise between slight rotation of the bearing and easy shifting. Also be sure the TA is adjusted right. I have a 460 Hi Utility with that problem that I have never gotten right.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1958 FORD RARE 4x4 801 TRACTOR, ELENCO/FRONT DRIVE, FRONTLOADER AND WEIGHTED REAR WHEELS, FIVE SPEED, LIVE PTO, GAS ENGINE, NEW REAR WHEELS AND TIRES, ENGINE RUNS.
[More Ads]
