Re: 656 pto slipping
Posted by Ponyroper on August 01, 2011 at 06:04:59 from (199.154.117.32):
In Reply to: 656 pto slipping posted by J Branning on August 01, 2011 at 04:03:18:
Had the same trouble a couple of months ago when the pto would stop turning when I put pressure on it by lifting the loader. Thought it was shot so I took it to the dealer and it turned out that the adjustment nut on the shaft that goes into the top of the pto and attaches to the on/off lever had backed off so far over the years that the pto was not fully engaging. They tightened the nut and now it works better than when I bought it. Might not be your problem but I would check it first before doing anything drastic. There is also a place on the pto that you can hook up a pressure guage to see what kind of pressure you have from your pto pump. Mine showed zero because the pump wasn't engaging when I threw the lever. I'm no mechanic or I should have probably known that. Cost me $120 to find out but that's a lot cheaper than the $800 they quoted me for overhauling the pto.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
