Re: oil for cub
Posted by Burrhead on August 13, 2000 at 09:35:04 from (12.74.17.24):
In Reply to: oil for cub posted by DB on August 12, 2000 at 19:51:03:
When you go to jump it off just engage the Cub starter button and stick the cable directly to the main battery lug on the Cub starter after it's engaged.
Look at the battery to make sure how it's in there, because the Cub should be a pos grounded system. That means you put the pos from the boost vehicle to ground on the Cub.
In other words when you boost off anything the cables still go to like post no matter how it grounds. Pos to Pos, and neg to neg, but if you hook directly from 12 to 6 volts at the battery, the 6 volts will probly explode in your face.
Post A Followup
: Re: Re: oil for cub
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
