Re: 656 pto slipping
Posted by Bill46 on August 01, 2011 at 05:11:07 from (192.131.177.18):
In Reply to: 656 pto slipping posted by J Branning on August 01, 2011 at 04:03:18:
If the oil pressure is good and the hyd filter clean, you have worn clutches.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
