Re: 706 Transmission Oil Leven
Posted by Allan In NE on June 28, 2011 at 06:12:41 from (148.66.88.254):
In Reply to: 706 Transmission Oil Leven posted by Ponyroper on June 28, 2011 at 05:33:06:
There is no ignition timing when you shut the tractor off. Just a hot chunk of metal rotating and sucking in fuel. Therefore, ignition timing has zero effect on your dieseling problem.
Make sure your throttle is closed before you kill the tractor and that the idle speed is set nice and low.
Allan
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
