F-14
Posted by TLK on August 05, 2000 at 19:44:56 from (38.37.12.71):
My F-14 was badly flooding.On advice I have gotten from you good people,I have solved that problem.However,when I pull the throttle back now,instead of black puffs of smoke,I get the cutting back as I was before.It will eventually pick up,but sometimes it will cut off.If I pull the throttle slowly,as in one notch at a time it will do ok.Secondly,the engine wants to race up and fdown as I pull the throttle and when I push it back down it starts idleing down and will speed up and down for a moment before it finally stops.Will the mag coil cause the problems of the cutting back.If so how can I check it to see if its weak?And lastly,isnt there suppose to be a spring in the governor somewhere and if so where?Could that be the cause of my surging problems/Again I thank you good people.TLK
JTA that I fixed my flooding problem by adjusting the float.Think I may have gone too far on it?
Post A Followup
: Re: F-14
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
