Re: 6 volt
Posted by Ludwig on June 09, 2011 at 09:15:22 from (68.162.248.195):
In Reply to: 6 volt posted by joe300chickens on June 08, 2011 at 19:40:28:
I went back and re-read your original post and I STILL don't understand what you're talking about.
Does the battery meter backwards now? You put the black from the meter on the - post and red on the + post and the meter reads negative volts?
I'm thinking your chances of coming out of this with a good battery are pretty small...
That guy you talked with clearly has NO CLUE how batteries work.
Loads of batteries get connected backwards (IE negative ground) in these old Farmalls, I did it back when I didn't know any better. Other than usually killing the voltage regulator it doesn't really do the battery any harm at first. The problem is you run the battery down since the regulator/generator can't charge it backwards so if you don't realize whats going on you ruin the battery pretty quick.
Anyway I like to slap some red paint on the ground cable on my old Farmall ('52 Super M) as a visual reminder as to which cable goes where...
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
