Re: Farmall A vs Super A
Posted by El Toro on June 03, 2011 at 15:04:43 from (108.15.86.54):
In Reply to: Farmall A vs Super A posted by charlie M on June 03, 2011 at 12:20:40:
The Super A's serial numbers started at 250000. Hal
If you can't find the SN look for a flat machined surface on the engine block below No1 sparkplug. I will be covered with paint and dirt
and should have a number stamped into the block.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
