Re: Super C Quit
Posted by Ferd on May 01, 2011 at 08:36:47 from (50.39.110.138):
In Reply to: Super C Quit posted by Wi-Ed on April 30, 2011 at 19:25:31:
With the switch on, check for power at the coil with a test light. If none (be sure the test light has a good ground) pull out the switch and watch the amp meter. If it doesn't jump and go to discharge, the switch is bad. When I painted my 230, I put a new switch in and a year later the tractor just died one day. Found that when the switch was pulled way out it was dead but if I pushed it in just a little it would work. Lucky I saved the original 50+ year old switch which I put back in.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
