Re: Super C Quit
Posted by Loren in MN on May 01, 2011 at 07:16:24 from (97.116.25.57):
In Reply to: Super C Quit posted by Wi-Ed on April 30, 2011 at 19:25:31:
Does it have a distributor? I had this happen the winter, checked everything -gas flow,spark,voltage to dist,coil. Found that the gears in the dist had jumped a notch or two due to worn gear, changing the timing. Bought replacement gears from Mark's Magneto in Rice,MN (he has them made) -after reassembly with proper settings -end of problem, she started right up.
Took a week or so to get it figured out during the cold winter. The tractor stopped while plowing snow.
