Re: F30 Trans Spins Too Long After Clutch Disengaged
Posted by Regularman on July 21, 2000 at 09:36:40 from (147.160.180.17):
In Reply to: F30 Trans Spins Too Long After Clutch Disengaged posted by TMAC on July 20, 2000 at 19:46:53:
Bill is correct but actually there is a third problem that can cause this. If the fingers on the pressure placte are not adjusted correctly they will hit the throw-out bearing at different times. This will cause the clutch to drag. I had this happen also in an F-20. BTW, the oild in the tranny would not affect this problem.
Post A Followup
: Re: Re: F30 Trans Spins Too Long After Clutch Disengaged
