Install Power Steering 300
Posted by Lee Jr. on February 27, 2011 at 06:11:20 from (4.245.87.11):
Please, would like some opinions on power steering retrofits for a 300 that have worked for you folks. Ran a search and found some posts and good info, but since they were a good while back I thought I would ask. I have a Behlen PS unit and I understand there needs to be a priority valve installed that will also meter GPM. One option I found is an OEM (or type of) unit that either replaces or adds to my existing regulator/safety valve on the left side of the tractor. I believe there is also a plug that needs to be installed, not sure what that does. Other option I found is to install a priority valve (Prince or similar) on the high pressure side to the PS unit. I would appreciate advice on what PS retrofit you found acceptable. I have a trip bucket on the front and its just flat getting too hard to turn the wheel. Thanks in advance
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
