Re: International 444 Oil Pressure
Posted by ltf in nc on July 16, 2000 at 10:44:17 from (206.228.214.96):
In Reply to: International 444 Oil Pressure posted by DHunter on July 16, 2000 at 09:10:43:
You did not state the weight of oil you are using or the number of hours on the engine and that could help ID your problem. It sounds as if you have a clearance problem(s) in the oil passages. Cam and main bearings also enter into this discussion. Changing the spring pressure is often attempted but that is not the solution. Wait until after you tear down the engine to order anything other than Plastigauge. With the Plastigauge you will be able to acertain the clearances on the main and connecting rod bearings. If these are out of spec, then you will be able to determine your needs. Good luck.
Post A Followup
: Re: Re: International 444 Oil Pressure
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
