Re: Swapping JD A for Farmall F-20
Posted by 36F30 on February 04, 2011 at 17:22:55 from (71.214.217.123):
In Reply to: Swapping JD A for Farmall F-20 posted by 43warhorse on February 04, 2011 at 06:40:17:
Unstyled A's came in 1934,well before the M. The A competed first with the F30 and was thoroughly outclassed. The B was the competition for the F20. The H(JD) with the F12. John Deere was trying to catch up with the rowcrop revolution started by the FARMALL. They failed.
As for how much a grey F20 is worth depends alot on how its equipped. Narrow treads are worth more, overdrives add to the total, roundspoke rubber, factory High Altitudes etc. For example an early low serial number High Altitude Narrow on F and H roundspokes with a Heisler overdrive is worth alot more than a widetread 37 on cutoffs.
