Re: F-12 to f-14 conversion
Posted by Athol Carr on December 22, 2010 at 15:21:30 from (219.89.92.232):
In Reply to: F-12 to f-14 conversion posted by farmerphil on December 22, 2010 at 09:04:00:
The bevel gears from the input shaft to the belt pulley shaft in the gear-box changed to accommodate the change from 1400 rpm of the F-12 to the 1650 rpm of the F-14 so that the change in engine speed did not alter the speed of the tractor or belt pulley. The gears to the power take off also changed from a 2.6 to 1 to a 3 to 1 ratio to give 550 rpm versus the old 540 rpm. The pto gears were also the oiler gears for the gear-box.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
