If that part # is for a conversion kit, doesn't it list what is in it? I know the engine speed was adjusted up by 200 RPM which gained about 2 HP, the PTO drive gear in the transmission was changed to retain the original shaft speed, the steering shaft was raised and a universal joint was installed next to the front pedestal, the seat was raised by installing a taller post and a different spring, and longer brake handles were installed due to the increase in the height of the seat. I'm not sure if the valve cover was changed as a part of the conversion or not. The F-12 used a restricted street el fitting with a piece of pipe on the front of the engine block as a crankcase breather. The F-14's use a different valve cover with a factory breather tube that extends down behind the magneto. The F-14 block has a pipe plug installed in place of the restricter fitting. Hope this helps.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
[More Ads]
