Re: 624 Tractor
Posted by J. Schwiebert on November 29, 2010 at 16:40:51 from (216.201.43.227):
In Reply to: Re: 624 Tractor posted by Jimb2 on November 29, 2010 at 15:29:39:
Thanks for the reply. The engine is not the problem. It does not move and if it is not the clutch then we need to find a parts book and a shop book to beg borrow or steel. J.
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
