Re: PTO CONVERTER
Posted by ltf in nc on June 28, 2000 at 18:46:43 from (206.228.214.216):
In Reply to: PTO CONVERTER posted by PAUL on June 28, 2000 at 17:39:57:
Paul, Many tractors have both 1000 and 540 RPM power takeoff capabilities. Typically, you just remove the existing pto and plug the replacement shaft in in its place. The tractor is designed that when the 540 shaft is installed it turns at 540 and when the 1000 rpm shaft is installed it turns at 1000 revs when the engine speed is running at the pto drive range on the tach. I would think your tractor is so equipped but my familiarity with the 1466 is limited. Probably someone that is knowledgeable with your particular tractor will post an exact answer.
Post A Followup
: Re: Re: PTO CONVERTER
Today's Featured Article - 50 Tips for Ford N Owners - by Bruce Haynes. Over the years of owning these three tractors, I have managed to refresh what little mechanical knowledge I had and add a little more, thanks to the wisdom and helpfulness of many fellow N owners. So, now it's my turn to share a few of the tips I've picked up. ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
