Re: generator, regulator or cut out
Posted by gene bender on November 13, 2010 at 02:30:12 from (67.55.227.196):
In Reply to: generator, regulator or cut out posted by Dave Cook on November 12, 2010 at 15:03:23:
The C Farmall you have is the device mounted on top of the gen. If it is its a cut-out. If it is mounted on the bottom of the bracket that holds the gen you have a generator unless someone has did some changing around just remember its an old tractor and you dont know when it was built as you didnt mention any serial#s or cast code #s. take it along with the gen when you go to the shop.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
