The third brush with a voltage regulator, will need to be set to the max output. (as close to the fixed brush as possible) With no way to look at them, the VR and the Cutout look similar. If there are 4 terminals on the device (L, BAT, GEN,FLD) then it is a vr. If there are three, it can be either a VR or cutout. If it are three, and the F terminal is not connected, and the Light switch has 4 positions and a wire connects from the light switch to the F terminal on the gen, and the Bat connects to the Amp meter, and the ARM connects to the GEN A terminal, it is a cutout, with operator control of charging rate. L for daytime operation, H for charging at first, or when the tractor is shutoff and started repeatedly, and D for dim lights and full charge, B for bright"ish" lights and full charging rate. If it has a 3 position light switch it will more than likely have a VR. Complex, but that is the story. Jim
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
[More Ads]
