Posted by Mark W. on November 04, 2010 at 05:41:56 from (64.83.132.2):
Well my buddy borrowed my tractor again to cut firewood. No problem, he is a real good friend and does a lot for me. Apparently, he had a chain wrapped around the fast hitch on my IH 340. He needed to unhook the trailer in the woods at some point to pull out a log and let the arms down to set the trailer on its jack. One of the cylinder hoses got pinched and started spraying at the fitting. Guess its time to replace another hose. Also, learning as you go, my $500 super A is up to over $3000. But, it is almost done and I sure have learned a lot from all of you and now know better what to look for when I see a "cheap" tractor I want to redo. Thanks
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
