350U PTO leaking at input lever
Posted by Formerly PaMike on November 03, 2010 at 17:23:51 from (24.152.202.123):
I have a 350U that is leaking oil at the shaft that turns the pto on and off. I disassembled everything and took out the shaft and bushing that control the bands. This is the shaft that is leaking. The feel on the bushing on the shaft feels good, with minimal play. The problem is when you assemble it and put preload on the bands with the adjusting screws, the bands push down on the shaft, causing it to cock in the bushing.The far end of the shaft moves up just enough that you can see that the lower part of the seal isnt touching the shaft anymore. This lets it leak oil. Anyone ever seen this before? It appears to just be a poor design. The shaft and bushing only had about .005"clear, so I dont think you could do much tighter...
Ideas?
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
