Re: 3-16's too much for my M, SM and MD???
Posted by The Dukester on October 23, 2010 at 19:02:03 from (209.86.226.40):
In Reply to: 3-16's too much for my M, SM and MD??? posted by Matt Weltz on October 23, 2010 at 18:17:35:
A Super M in good condition should be able to handle 3-16's in virtually all soil conditions. Most M's, MD's and Super MD's that have been overhauled got increased bore piston/sleeve kits in the process and this gives most of them enough power to handle 3-16's too. Of course there is always some condition or type of soil that is extremely hard to plow such as tight clays and sodded or hard packed ground that is quite dry. The tractor will always need good proper sized tires with additional weight on the rear wheels and maybe some front end weights of a sort too if the plowing conditions are tough. Excessive rear wheel slippage makes plowing difficult and robs horsepower that is needed to "get to the ground" to efficiently pull any plow that is rated to the tractor's capacity.
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
