Re: 706 LEAKING
Posted by steve706 on October 13, 2010 at 13:15:58 from (216.208.94.140):
In Reply to: 706 LEAKING posted by C.R. on October 13, 2010 at 13:02:17:
If you want an exploded view go to a case ih dealer web site and they usually have a parts look up you can access. Everything is on there. As for the leak it is probably just the hyd lines for the steering and not to hard to fix.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
