McCormick-Deering 22-36 Project
Posted by Tom in Iowa City on October 06, 2010 at 15:06:21 from (173.29.204.53):
Hello again,
I have posted images showing the latest developments in my project. I used Mark Stephenson's formula in DuPont Centari.
Sandblasting was done, epoxy primer sprayed and then the Centari.
My next step is to remove the axle carriers, bull gear cover and other masked areas, check for sand, wash out, dry and assemble the bull gear, rear axles, brake drum shaft, front axle, steering knuckles and knuckle arms, stay rod, bolster and steering connection.
Then, I'll mount my blasted and red-painted wheels. Last, I'll add the rubber to the smooth wheels.
Notice how different the paint job looks when seen with different lighting/flash conditions.
Tom
third party image
third party image
third party image
third party image
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
