try bringing #1(fwd) cylinder piston to to dead center on compression stroke and see if there is any kind of a mark on timing gear, dot, line,camfered tooth ect. then rotate the distribtor/mag till rotor is pointing to #1 terminal on cap and see if dis/mag drive will line up when gear is installed with dots meshed with timing mark on gear. this should get you close enough to adjust dis/mag by rotating till the points just start to open. good luck, d.coleman
Today's Featured Article - Preventing Tractor Theft - by Staff. The discussion started with the following message: I have a JD A without key start or any locking device. Is there a best way to secure it so the chances of it being stolen are reduced? Following are some of the answers that were received: Take the rotor out of the distributor and hide after each use. The would-be thieves at least couldn't just get on and drive away.
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
