Re: Re: Re: Hey RED
Posted by The Red on June 18, 2000 at 09:59:14 from (12.75.196.121):
In Reply to: Re: Re: Hey RED posted by RKS on June 16, 2000 at 12:08:12:
Your pump might be a little worn. All my Hs drop some after warming up. 40 is more than adequate at operating speeds. Glad you found the problem. When you have time to kill, you might want to pull the valve cover and clean as much gunk out of there as possible. Next time you do an oil change and have the filter off, remove the rocker arm inspection plate (you will probably need a new cork gasket BTW) and clean those chambers as best you can. Those are the two primary areas for gunk buildup in the H.
Post A Followup
: Re: Re: Re: Re: Hey RED
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
