Posted by Janicholson on September 21, 2010 at 17:45:52 from (67.72.98.45):
In Reply to: Farmall C mowing posted by TxFarmall on September 21, 2010 at 12:12:53:
It will be fine with the bush hog style mower. Make sure the front edge of the blade/s are lower than the rear by about 1/2" when the blades are turned so that they/it is front to rear. This reduces re-cutting and lowers required power by 30% or so. Use a overrunning clutch on the mower drive shaft for safety and convenience in operation. Start in an area of the field with less growth, and work out from there at 50% cutting width. Don't expect miracles and it will make one for you. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
