Re: 666 Gas
Posted by Janicholson on August 31, 2010 at 18:37:44 from (67.72.98.58):
In Reply to: 666 Gas posted by Erik Dekeyser on August 31, 2010 at 18:31:51:
If the spark is getting to the plug, (put a plug on the end of the wire, lay it on the block and start it. If the plug fires, I would then move the #3 plug to number 2 hole and see if the missfire follows the plug. If so replace the plug.
If it does not, it will be necessary to do a compression check on the cylinder. If the compression is off, or different, I would pull the valve cover and check the valve operation. If the valves are working, (set them while you are in there) and do a cylinder leak down test. Jim
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
