Re: 303 combine engine in a 656?
Posted by ejr-IA. on June 13, 2010 at 11:38:11 from (204.11.182.38):
In Reply to: 303 combine engine in a 656? posted by 49 Studie on June 13, 2010 at 05:17:50:
Sure you can use it it will be a little shorter on power than the original,but not much.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
