Re: 303 combine engine in a 656?
Posted by The tractor vet on June 13, 2010 at 08:08:14 from (76.212.236.89):
In Reply to: 303 combine engine in a 656? posted by 49 Studie on June 13, 2010 at 05:17:50:
Well with out knowing what engine is in the 303 as i never payed much attention to what engine was in the I H combine as i have never owned one or worked on one i do not know is it is a C263 or not. BUT i do know that it will not be a direct bolt in as the ft timing cover will need swapped out along with the rear engine plate oil pan and pick up manifold carb and some other things. Myself i am lazy and why would i want to tear down two engines to make one when i could just REBUILD what was in there and then know what i have , but that is just me .
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
