The Bat terminal is connected to the Battery. Thus you are reading Battery voltage, not charging voltage. It is not charging. First polarize the generator. (with it shut off, all wires where they are supposed to be attached, and with a charged battery) Jump between the Bat terminal on the regulator, and the Arm terminal on the Regulator. This puts residual magnetism in the field of the gen. Try it if all is well great. The procedure linked will help. Jim
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
