Re: Water in hydraulics
Posted by Jim Becker on April 28, 2010 at 16:47:07 from (173.57.149.7):
In Reply to: Water in hydraulics posted by jc newton on April 28, 2010 at 04:48:40:
Do NOT put Diesel fuel in a Touch-Control system.
Drain the system, then start the engine briefly to kick out some of the oil in the pump and lines. Refill with a good hydraulic oil and run it a bit. If it is still milky, do it again. This process will probably go better using genuine Hy-Tran as it will absorb more moisture than most of the generics.
