Re: Touch Control block
Posted by CNKS on April 14, 2010 at 14:38:29 from (216.144.104.128):
In Reply to: Re: Touch Control block posted by El Toro on April 14, 2010 at 09:46:48:
Thanks, I also looked in the I&T manual after I posted. Diagrams are actually clearer than in my parts book and service manual. The one for the Cub is even better. Different block, same function. So I'll use the long one for the safety valve.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
