Re: Farmall C clunk
Posted by farmerjohninpa on April 05, 2010 at 21:33:45 from (64.136.27.226):
In Reply to: Farmall C clunk posted by Dougct on April 05, 2010 at 12:15:56:
jim is right about the coupler,,,i had the same noise as you are experinceing when i first had my bn . i can not say exactly what mine was, but when i split the tractor and replaced the clutch,pressure plate, throw -out,,and put new bolts to the coupler. the noise was gone when it was reasembled and test run.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
