Re: coil resistor
Posted by jdemaris on March 31, 2010 at 09:12:04 from (67.142.130.47):
In Reply to: coil resistor posted by Mark W. on March 31, 2010 at 05:13:05:
A common one is the NAPA ICR-13 that is rated as a 1.8 ohm resistor.
It will work fine with just about any coil that does not have its own internal resistor.
If not sure, just take a reading across the two primary terminals. Should be 1.4 to 2.4 ohms.
If you get a reading over 3 ohms, you do NOT need an external resistor.
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
