Posted by Blackland Dan on March 23, 2010 at 13:23:07 from (206.248.34.106):
In Reply to: Re: Cylinder sleeves posted by Andrew Z on March 23, 2010 at 11:12:46:
Thanks, Andrew. I'm not sure I want to get into boring. Would there be enough power benefit from the domed pistons to offset the cost of the pistons? Dan
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
