Re: Hydraulic question
Posted by Janicholson on March 18, 2010 at 19:06:16 from (64.61.211.104):
In Reply to: Hydraulic question posted by Spotted Horse on March 17, 2010 at 22:58:21:
Two issues:
The reservoir should be the loader frame, not the under hood unit.
The Second issue is that the PTO pump is probably designed for 540RPM Maybe up to 700 if it is a good pump.
The Belt pulley will be in the area of 1200RPM and should be connected with a belt ratio of 2 to 1 reduction. Best of luck, Jim
Today's Featured Article - Tractor Profile: Oliver 70 Row Crop - by Staff. The Oliver 70 was part of the "Fleetline Series" and was manufacturered from 1937 to 1948. The row-crop configuration could have either dual or single front wheels. The Oliver 70 was also offered in the standard, orchard and industrial configurations. The tractors were sold in Canada. An early advertisement states "Power when you want it - power when you need it - power to help put in crops when field conditions are right and time and help are limited. That's the power you'll find in an Oliv ... [Read Article]
