Re: H hydraulics
Posted by Andrew Z on January 23, 2010 at 17:27:04 from (64.252.113.90):
In Reply to: H hydraulics posted by CJ_1080 on January 23, 2010 at 17:23:35:
go with a PTO driven pump, that way you will have plently of gpms and pressure to run a splitter. You can see them on ebay once and a while. Brand new there around 500 for a 20 plus gpm pump.
Andrew
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
