Re: Battery Cables
Posted by CNKS on December 16, 2009 at 18:39:13 from (216.144.104.128):
In Reply to: Battery Cables posted by Bernie Steffen on December 16, 2009 at 16:27:25:
With 12 volts, 2 or 4 gauge is ok. The starter does not care what the voltage is. The most important thing is to have clean connections, and be sure there is no corrosion inside the cable near the connection. The biggest problems are the 24 degrees and not starting it for 3 months. I often run into the same problem as I only run my tractors in the winter if I need to blade snow, in SW KS, that is not very often. It helps to charge the battery first, use no choke when cranking to prevent flooding, if it fires, try to pull out the choke slightly before it dies. Your problem is normal for an H or M, no big deal.
Today's Featured Article - Tractors and the City Boy - by Ken. A few years back I came to the conclusion that city life wasn�t for me. The houses so close together you could hear the neighbors fight, traffic so heavy speed limit signs meant nothing. So I started looking for the ultimate country setting. After many months I found the perfect place, off the beaten path, up a private � mile drive, old stone house which has stood the test of time, out buildings which haven�t stood the test of time, trees, birds, rabbits, and snakes. This is the place! Bought ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
