Posted by Owen Aaland on December 16, 2009 at 17:56:10 from (65.161.86.2):
In Reply to: Battery Cables posted by Bernie Steffen on December 16, 2009 at 16:27:25:
The volt meter is your friend to find any problems here. While cranking there should be no more than .1 volt drop between any two consecutive connection points. No more that .2 volts drop across the switch. Be sure to check voltage drop between the starter case and the grounded battery terminal. The battery should maintain at least 9.5 volts, 10 volts or more would be better. Low battery voltage will be caused by either a weak battery or excessive draw in the starter. A battery load test will determine which one is at fault.
Today's Featured Article - Tractors and the City Boy - by Ken. A few years back I came to the conclusion that city life wasn�t for me. The houses so close together you could hear the neighbors fight, traffic so heavy speed limit signs meant nothing. So I started looking for the ultimate country setting. After many months I found the perfect place, off the beaten path, up a private � mile drive, old stone house which has stood the test of time, out buildings which haven�t stood the test of time, trees, birds, rabbits, and snakes. This is the place! Bought
... [Read Article]
