Re: Battery Cables
Posted by Andrew Z on December 16, 2009 at 17:21:04 from (64.252.44.45):
In Reply to: Re: Battery Cables posted by Bernie Steffen on December 16, 2009 at 17:11:09:
thats good welding cable is the best wire to use. maybe poor connections at the post ? have you had the battery load tested to verify its good, not just with a volt meter. how many CCA does the battery have ? trying to just go down the list in my mind here.
Andrew
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
