Re: H rear tire size
Posted by Janicholson on December 13, 2009 at 18:16:08 from (64.61.211.151):
In Reply to: Re: H rear tire size posted by NDS on December 13, 2009 at 15:08:42:
NDS is very correct. Disking and dragging, contour farming, and all turns in the field under load "use" the differential. In a passenger car the issue is handling and safety of control. Both are affected by tire size and rolling diameter. In the tractor it is no issue at all. Jim
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
