Re: Super A is very cold and cannot be towed.
Posted by gene bender on December 12, 2009 at 07:01:47 from (67.55.226.179):
In Reply to: Re: Super A is very cold and cannot be towed. posted by Haas on December 11, 2009 at 17:39:46:
Realy how much air would be forced around the spring loaded cap on the tranny. The only way for any air to get thru into final drive would be thru the seal behind the brake drum and axle. Now ifn ya let the tractor set outside and gaskets and seals are shot you will get water along with many other problems The bottom line is it you dont care enough about your tractor and let it sit outside in the elements you soon will have a pile of junk.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
