Yep BTDT and had that problem on my Ford just yesterday. So did you try to turn it over with the clutch pedal down or did you do it with it up??? My ford would not turn over unless I had the clutch down and then it would start right up but stall if I let up on it. I ended up starting it and letting it run for 30 minutes or so and it got warm enough to be able to use the tractor. Later I will crack the drain plug and hopefully the water will drain out. Ya I plan to change the oil in the tranny but have to wait on some $$ to come in before I do
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
