Re: ih 706 wont start
Posted by Ryan Mcshane on December 09, 2009 at 17:25:15 from (129.186.253.74):
In Reply to: ih 706 wont start posted by oslodan on December 09, 2009 at 17:09:56:
Look at the distributor cap first. Make sure the contacts inside are clean and no moisture is present. Check the rotor and make sure it is clean as well. You cant get fire to the plugs if tese items are corroded. Wires could be wet as well if exposed to moisture...take them inside and dry them?? Hairdryer may work.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
