Posted by gene bender on October 23, 2009 at 04:30:57 from (67.55.226.179):
In Reply to: farmall BN brakes posted by S.Gross(in pa) on October 23, 2009 at 02:39:04:
No they are just worn as i assume you have tighteden the linkage. You can get bonded linnings or get the linning and rivet them your self. I reline my own as i have lots of time ialso put the drum in the lathe and take a sharp tool make a slight cut on the drum sure gives the new linning something to grab to.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
