Re: 6 volt Farmall Starter
Posted by Dave H (MI) on October 20, 2009 at 11:35:41 from (205.188.116.73):
In Reply to: 6 volt Farmall Starter posted by S/C Bob on October 20, 2009 at 08:04:45:
I just went thru that on a 6 volt Ford system...it were a trial. You need to start at the battery and work thru the whole circuit. Test the battery. Make sure the cables are the recommended size for 6 volt as mentioned below. Check your switch for continuity. Make sure every single connection has been disassembled and cleaned bright including where the starter grounds to the engine. Tighten it all down good. You learn thru experience that 6 volt systems can be sensitive to bad connections because of dirt and rust. "Clean, bright, and tight" with apologies to the N board guys!
