Posted by Hugh MacKay on September 22, 2009 at 01:48:44 from (216.208.58.190):
In Reply to: c 22 sickle mower Info posted by welder41 on September 19, 2009 at 04:47:00:
Welder: The Cub mower will not work on a SA, 100, 130 or 140, nor will the SA, 100, 130 and 140 mower work on a Cub. The problem being different rotation of the PTO. The pitman arm flywheel is threaded onto shaft, and will spin off threads when used in wrong direction.
Save yourself a lot of work changing the mounting, only to find it won't work.
Today's Featured Article - Tractor Traction - by Chris Pratt. Our first bout with traction problems came when cultivatin with our Massey-Harris Pony. Up till then, this tractor had been running a corn grinder and pulling a trailer. It had new unfilled rear tires and no wheel weights. The garden was already sprouting when we hooked up the mid-mount shovel cultivators to the Pony. The seed bed was soft enough that the rear end would spin and slowly work its way to the downhill side of the gardens slight incline. From this, we learned our lesson sinc
... [Read Article]
Latest Ad:
[More Ads]
